Why can't I find headlight assembly for an 01 seville sls
Once you take off the 2 bolts that attach the headlight to the frame and remove them, you will see clips that hold the 2 pieces of the light together. Gently cut the glue (either a heat gun, exacto blade etc) and separate the pieces. Good luck!
