Tail Lights
Old Aug 18, 2008 | 11:23 PM
fanta101's Avatar
Default Tail Lights
Does anyone know about the faulty tail lights on the 92-96 Seville.I have a 93SLS and I replaced all the bulbs in the rear and the tail lights work but when I put on the brakes, one bulb on the left (drivers side) won't double light up. It stays on tail light. The bulbs are all new and I've tried different new bulbs, same thing happens. I have noticed every other 92-96 Sevilles on the road and when they brake in front of me, the bulb or bulbs don't light up on the left side. Is it a short? Is it the socket? Was there a recall bulliten from Cadillac saying it was a factory defect?
Also I did a code check and what came up was P070 History, I022 History, I039 Current, I052 History. Does anyone know what these are. Of course this car is pre-OBD II.
Thanks!
vince
Old Aug 23, 2008 | 12:03 PM
greezyseville's Avatar
Default RE: Tail Lights
have a 96 seville with same problem you have a bad harness on the left side
Old Aug 24, 2008 | 08:26 PM
xmguyx22's Avatar
p070 - Intermittent TPS Signal
i022 - RF Wheel Speed Sensor Frequency Error
i039 - Loss of Road Sensing Suspension Data
i052 - Keep Alive Memory Error
These are what the codes mean. The codes with history after them means the codes were cleared. This necessaly doesnt mean that the codes were fix though.
Old Oct 4, 2008 | 10:13 PM
dimitri94seville's Avatar
i have a 94 sls and the i have the same problem, changed all bulbs and one tailight dont light when brake pushed. some wiremightbe faulty
TERRYRIC
Apr 6, 2009 10:51 PM
BOBBYRIC1
Jan 13, 2009 07:50 PM
fanta101
Aug 19, 2008 08:15 PM
ridin_low07
Sep 25, 2007 02:32 AM
Refugeez
Jun 4, 2007 05:32 AM
