2001 STS Door Lock Problems?
Old 06-08-2010, 06:47 PM
1fast4door's Avatar
Default 2001 STS Door Lock Problems?
I am trying to fix an '01 STS with door lock issues. Weekend before last on a long road trip the door locks started locking over and over again, never unlocking just trying to pull down, and the theft light on the dash would light occasionally. Not thinking that it was a big deal it was parked and the next morning the battery was dead. The battery got charged it made it home with the same results, doors locking repeatedly. Once home I pulled the codes and got these.
AMP
B1327 - Vehicle system voltage below 9.0 volts
U1000 - Generic class 2 Failure/ Loss Class2 Communication of DIM
DDM
B3832 - Left Front Window Down Switch Circuit Low
B3833 - Window Position Sensor Circuit
U1713 - Loss of Front Door Module to Window Motor High Speed Comm
DIM
B1983 - B1983 System Voltage Low
IPC
B1004 - Loss of Keep Alive Memory
IPM
B1652 - KAM reset
IRC
U1064 - Loss of Communication with BCM
U1065 - Loss of Communications with IPM
U1160 - Loss Of DDM Communications
U1016 - Loss of PCM Communications
MSM
RFA
U1305 - Class 2 Bus Shorted to Ground/ Battery
RIM
B1328 - Source/Battery Voltage High
TTM
B1982 - System Voltage High
B1983 - System Voltage Low
After looking over them I assumed that most of them were from the dead battery and the charging so I cleared all and cycled the locks and windows. I then pulled the codes again and got.
DDM
After looking on-line, I came across this link
http://www.justanswer.com/questions/...-3833-pcmp0420
So I tried it and it seemed to work, I let it sit for a while and then pulled codes again.
DDM
B3172 - Window Up Switch Circuit Low
B3382 - Left Front Window Down Switch Circuit Low
From what I have read, these codes could just be from the process of setting the express feature.
I then cleared codes again and sat and watched the car for a while. I could hear the locks trying to pull down and the tail lights were flashing on and off randomly after a half hour or so I pulled codes again and there were none. Without any new codes in memory I am not sure what to try next. I am going to check out the battery, from what I hear these cars are sensitive to weak batteries. Other than that BCM? DDM? I find it odd that there were no VTD codes though, with the symptoms that were presented. Can someone help me out here?I am not sure which direction to take. It will be greatly appreciated.
George
Old 06-09-2010, 12:12 PM
2001_Seville_SLS's Avatar
Default Window codes
The codes are not related to not setting the express up operation. Here is why: First, all of those codes don't show up together if you don't reset the windows after disconnecing the battery. Second, if the windows were reset and your express up operation , the one touch operation, was working on both front windows when you cleared the codes, then the codes are definately not related to failure to reset the windows.
The codes along with the haunted door switches indicates a poor electrical connection to the RIM.
1. Check if pulling the IGN SW fuse #29 stops the problem.
2. Check the IGN SW fuse for corrosion.
3. Check the connector at the RIM for a good connection.
4. Check the power and ground conductors to the RIM.
The RIM is located behind the right rear passenger seat and is accessed thru the trunk.
Old 06-09-2010, 07:04 PM
1fast4door's Avatar
Thumbs up
Thanks I will try to check that out this weekend.
George
TheJoker
Vintage & Classic Cadillacs
09-23-2014 12:17 AM
zigyblu
08-05-2013 08:56 AM
nubirth
05-19-2009 08:22 PM
nubirth
05-19-2009 02:40 AM
theatreman
04-16-2007 02:34 PM
Quick Reply: 2001 STS Door Lock Problems?
