By Pass the heating system in a 95 Seville
Old Sep 14, 2008 | 02:05 PM
NESCAPOLIT's Avatar
Default By Pass the heating system in a 95 Seville
Some how all the cooling fluid poured on the driver side area uder the dash board were few men had gone before.
I was thinking inted of trying to fix it and go for a torture of taking apart all the interior of my car in order to reach the broken hose or.. just by-pass it.
Can this be done in a 95 Seville, since I livein a HOT state (FL)were all I use is A/C and never the heater, or will this affect other systems?
I alredy know how temperamental this lady can be so I am asking for advise.
Thank you in advance...
Old Sep 15, 2008 | 09:59 AM
Default RE: By Pass the heating system in a 95 Seville
ORIGINAL: NESCAPOLIT
since you didnt use it, heater core probably failed.
bypass it, hose to hose.
car systems with seals and/or fluids need to be used at least a few times a year to keep them in a well condition.
Old Sep 15, 2008 | 06:28 PM
NESCAPOLIT's Avatar
If I may, could Iask you for some other related advise:
Coming out the coolant resevor (tank) there is a pipe that split in to two hoses that get in to the interior were the coild should be, however the water pump which is in the oposite side of the engine has a pipe / hose that goes in the direction of the back of the engine presumebly to the heater coil.
Which one should I conect and or should the by pass be betwen the water pump hose and the tank?
Thank you again for your helpful advise.
texas tony
Apr 5, 2012 07:00 PM
z24cruiser
Apr 7, 2011 02:18 PM
cady2
Mar 25, 2007 12:20 AM
Superado
Aug 7, 2006 06:58 PM
cady2
Sep 25, 2005 11:44 PM
