Fuel tank pressure sensor
Old Jun 30, 2020 | 06:19 PM
STSSCOTT's Avatar
Default Fuel tank pressure sensor
Hi all!
Hope someone can help a fellow caddy owner out here! I have a 2002 seville sls and was told that the tank pressure sensor was shot, i got a new one but for the life of me i cannot find where it goes, you tube is no help on this one.........thanks in advance any help is appreciated!! Stay safe!
Old Jul 1, 2020 | 10:41 AM
dtcassist's Avatar
Former Sponsor
The fuel tank pressure sensor is mounted right into the top of the fuel tank. I believe you are one of the lucky ones that has an access panel in the floor of the trunk to get to it. Otherwise, it's dropping the tank to get at it.
Why do you think it's bad? Is it setting a check engine light?
Old Jul 1, 2020 | 02:12 PM
STSSCOTT's Avatar
We have emissions testing here in CT and it kicked back a code, (I forget what the code was) evaporative something? And my check engine light does not work, so the testing person gave me some ideas what to fix, starting with the gas cap and then this, code might have been PO442
Old Jul 1, 2020 | 02:45 PM
dtcassist's Avatar
Former Sponsor
P0442 indicates a small EVAP system leak - if that's what it is. I'm not sure the fuel tank pressure sensor would be a likely candidate unless it's physically damaged.
Evap leaks are tough to track down. Technicians use a smoke machine to fill the lines and tank with smoke to try to find it. The problem could be anything from a pinhole in the line going to the engine, rust through on the filler neck or top of the tank, or a leaky valve. I would inspect everything closely first, and you may notice a fuel smell if the leak is large enough.
Old Jul 2, 2020 | 06:43 AM
STSSCOTT's Avatar
ok, i will check....thanks!
Smash-n-bash
Sep 19, 2018 07:56 PM
Karl Schmidt
Dec 17, 2015 07:48 PM
Z51
Aug 22, 2008 07:43 AM
Diamond In The Back
Jan 3, 2008 06:09 PM
rcross
Jul 14, 2006 10:44 PM
