dropping engine - what a biootch!
Just want to vent a little about what a total bioootch it has been dropping out the front cradle! I have spent almost 20 hours so far and it's ALMOST ready to come out. Just need to loosen the 6 cradle bolts and jack up the frame. This is my first time wrenching on a caddy, and I can't believe how many frickin' electrical connections I had to undo... its wiring madness. Now i just hope my little labels dont fall off the plugs... [X(]I'd be so lost!
The car is a 96 with 148k, and I can tell this is the first time its ever been dissected. Some of these bolts are solid! The exhaust bolts are so rusted to oblivion, that soaking them in penetrating oil spray and a 250 ft-lb air gunis futile. I'm just snapping reducers / flex joints. So, I decided to drop the motor with the y-pipe/exhaust attached. A little more work disconnecting the exhaust all the way back to the muffler tips, but I see no other way to do it short of cutting the pipe, which I don't want to do for replacement cost reasons. Once I get it out of the engine bay and things are more accessible, I should be able to get at the bolts with the air gun and no elbow adapters. If it doesn't come out that way, I'll drill out the bolts.
Then last night, taking off the passenger side steering knuckle, the 2 really big bolts going into the flange on the coilover were ridiculously solid! The driver side ones came out with the usual super long breaker bar and some muscle. These ones weren't moving. I soaked them in penetrating oil. I already had the nut off, and the bolt is supposed to just slide out! It doesn't even need to be unscrewed/backed out. I couldn't even get it to turn!! Had the air gun on it full force 250 ft#, it aint budging. Spanking the heck out of the other end of it with a massive sledgehammer, reapeatedly for like 10 min... aint moving. After alternating spraying, air gunning, and sledgehammering for about 20 minutes, I FINALLY got them out. I have NEVER EVER seen such stubborn bolts!! Once out, it was apparent the bolt threads had formed a continous rust with the housing which they were slid through... kind of like a 10 yr slow weld. lol.
This project has been full of time consuming "surprises" (expected, as always)at every turn so far. I can't wait to find out what lingers beneath the heads! I'm banking on a blown head gasket and stripped out bolts. But who knows what lays ahead. Maybea cracked block? Oh, I can hardly wait! The suspense! [:'(]
Hey J : Sounds like you have been pretty damn frustrated. As hard as you have been working at that end I had a damn good laugh at this end. Good luck an think of how nice it will be to enjoy your ride again.......Chow.
Got the motor out last night! Whew! Took a total of 20 hours by myself on the garage floor with no lift.
How's that stack up to other people? Seems kinda slow to me...
Drama
Oct 6, 2020 09:45 PM
etohboy
Vintage & Classic Cadillacs
Sep 28, 2009 05:25 PM
420Deville
Nov 10, 2007 07:06 PM
