Clearing Fault codes?
Old Apr 13, 2008 | 08:51 PM
Darkrider83's Avatar
Default Clearing Fault codes?
I Just bought my 88 Seville last week and upon turning the key the first thing that shows up on the DIC is A/C sensor Fault warning. Now i have read about this fault in the manual and it states that the A/C will not cycle on and off if there is in fact a fault there. However my roomate and i were working on the car on friday (repairing some cooling lines) and when we started it to test and ensure the cooling system was in fact sealed i had started the A/C to put stress on the cooling and warm it up faster. The A/C is functioning perfectly fine we both heard the compressor cycle on and off along with getting ice cold air inside the car. Now my question is this..how do i clear the fault code? I know with some GMs you can just remove one of the posts of the battery or a fuse to clear the code then reinstall said parts..is the procedure the same with this model?
Old Apr 13, 2008 | 09:51 PM
Default RE: Clearing Fault codes?
Codes and how to clear should be in FAQ section or disconnecting battery will clear codes also.
Old Apr 16, 2008 | 01:12 PM
carnut's Avatar
Once cleared, it will return. A current fault will display, a history code will not. So, you need to fault trace this code. Its probably a 1/4 lb. low on freon.
phoretwan
Mar 16, 2014 08:49 AM
stinger
Oct 16, 2012 05:40 PM
banderson
Oct 27, 2010 05:43 PM
Robesp
Oct 17, 2010 12:31 PM
Ilya
Aug 28, 2009 08:53 PM
