Change brake pad error
Old Mar 13, 2007 | 11:12 PM
sneakie1018's Avatar
Default Change brake pad error
well i am stumped i changed my frontbrake pads on my 99 seville sls when changing I noticed that the right front pad sensor was ripped off no ccode came up before but ok. changed pads code change brake pad came on soooo i said well maybe i need to change the rears as well. sensor still on bought a new brake pad sensor and cleared all codes...shut off car and restarted code still came up tried a few times and repeated erase codes. the pads are fine front and back all the other sensors are on right. what the heck please help the dealer is toooooo expensive for something stupid
Old Mar 14, 2007 | 03:26 PM
Katzmans Caddy's Avatar
Default RE: Change brake pad error
Try disconnecting ground cable on battery and leave it off fora few minutes. Sometimes this helps erase codes in history etc...Reconnect and see if it still codes.
Old Mar 15, 2007 | 08:38 AM
thank you, actually i called another state cadillac dealer who specialized in cadillac repair and he said sometimes you have to disconnect all 4 sensors and clear all codes through the obd 2 system then replug them in. and restart your car.....wouldnt you know it worked. this is a great web site
Old Mar 15, 2007 | 11:26 AM
Default Change brake pad error SENSOR
excellent information to keep around.
thanks
ORIGINAL: sneakie1018
Old May 22, 2007 | 12:47 PM
deals4u04's Avatar
Did you really have to get all sensors disconnected then obd2 to clear then connect them again?
Old May 22, 2007 | 02:34 PM
G.A.R.Y.'s Avatar
My first try would be the battery for 5 minutes before I went any further.
Old May 23, 2007 | 06:26 AM
yes i had to disconnect all the sensors then go to the obd 2 go to all codes then clear all codes you hear the computer kick on then it will say all codes cleared. then replug in your sensors and restart you car.. i know pain in the *** but it works
tommy
Oct 3, 2014 04:50 AM
99STSGUY
Jan 21, 2009 08:29 AM
1989 fleetwood
Apr 23, 2008 12:03 AM
cosquare
May 12, 2007 07:26 AM
ruaskier2
Jul 18, 2006 03:21 PM
