96 seville sts - electrical
Old Apr 11, 2008 | 08:17 PM
sharkm87's Avatar
Default 96 seville sts - electrical
hey guys, i just got my hands on a used 96 seville sts, here are the issues.
one i'm getting service emissions, for a maf volume error code..so i'm assume just needs a new maf.
secondly. sunroof dosen't work.
third. abs sensor light ison
fourth. the traction control light stays on...i'm not sure if thats normal or not, but i press the traction control button in glove compartment and it does nothing.
fifth. the controls for the climate control dosen't work....i can turn the *** to raise and lower temps, however it never gets cold, and when switching between modes it shows its switching, however air only comes from defroster vents, wont switch to feet, or front ect.
Old Apr 21, 2008 | 01:04 PM
Katzmans Caddy's Avatar
Default RE: 96 seville sts - electrical
one - you may be right but check it to see if it is clogged or needs cleaning first. I have seen them all carboned up.
secondly -check fuses
third & fourth - abs runs traction control so these are probably related- sensor problem?
Fifth - does A/C compressor click on and off, maybe you need a leak test and recharge.
Old Apr 21, 2008 | 03:03 PM
sharkm87's Avatar
hey bro, thanks for the reply.
as far as the ac goes, i do not hear the compressor kicking on or anything of that sort.....all i can do is raise and lower numbers and change the fan speed which seems to work, but cant switch between feet/defrost/face ...seems as though heat is just coming from it....i'll do another once over on all the fuses, but thsy seemed to all be fine...i checked the ones in the trunk on left side.
Old Apr 21, 2008 | 09:18 PM
Car has vacuum actuators for air doors. Check for vacuum leaks, HVAC will default to defrost if no vacuum to programmer. Vacuum leak(s) can cause MAF code.
Old Apr 22, 2008 | 03:27 PM
sharkm87's Avatar
thanks, good to know..i def. didn't know that with this car...now is there vacuum lines in the dash or behind the hvac controls.....or should i be checkin for the normal leaks under the hood.?
lraguz
May 2, 2008 08:34 AM
Dmanders
Mar 19, 2008 10:39 AM
bmesa1972
Feb 18, 2008 08:29 AM
Vasile2
Sep 22, 2006 10:47 PM
devilleconcours100
Aug 29, 2006 12:50 AM
