94 Seville leaking oil bad!!!!!!!!!!!! NEED HELP!
I have a 94 Seville SLS. It is leaking oil badly. Driving down the road and at a stop light, smoke is comingfrom thehood.I recently changed the plugs and found the #6 plug soaked in oil. Any insights? I need to make this car safe and hopfully not catch on fire. Any help would be appreciated!
what part of the plug was soaked in oil?
the outside or the part that goes INSIDE the engine?
ORIGINAL: brad0502
either this quote OR the valve cover bolts got loose over time.
ORIGINAL: Katzmans Caddy
Smoking bad means oil on exhaust manifolds so it has to be coming from the heads. Gaskets gone bad on valve train covers?
Is there anything special to replacing the valve cover gaskets? At first glance it looks like the coil packs need to be removed. Do they? Is there any tricks, or things to look out for? Also what gaskets would you go with?
dont know what all your engine has up there in the way. i simply work my way through it.
mechanics may charge up to $500 to do the job. gaskets cost around $30.
the gasket is a simple as a clean up job, install new gaskets, apply sealer IF applicable,
and "TORQUE" properly. buy the best gasket you can find. the extra $5 or so will be
money well spent.
TORQUE properly - i cant say that enough times.
TORQUE properly.
seriously, TORQUE properly.
not tight enough and they will leak, again.
break them and now the job got really expensive.
money well spent.
TORQUE properly.
Felpro has a cover gasket kit, it includes the spark plug tube seals and grommets. Auto Zone wants like $70, but can find it on Ebay a few buck cheaper for the same kit. The coil packs lift out of the way, on my 98 sts there was 3 bolts holding down the tray the 4 coil packs are on.
astrodan13
Aluminum Block V8s
Jun 14, 2011 12:24 AM
gigantor
Mar 10, 2011 12:11 AM
Mar 3, 2008 10:14 PM
brougham1
Feb 24, 2008 07:41 AM
420Deville
Nov 10, 2007 07:06 PM
