92 seville
Old Jan 13, 2009 | 11:18 PM
utleyfamily04's Avatar
Default 92 seville
I have a 92 Seville that has a problem starting. I took it to a dealer and they said it was a bad pickup coil in distributor, so I bought a whole new distributor put it in and car fired right up. Smoked a little bit from fuel buildup, came right out of it. Drove the car all day starting and shutting it off. Drove like a dream. Car sat overnight came out in the morning and it wouldnt start. Turns over fine just wont start. Can smell fuel so I am pretty sure its getting fuel. Something to do with firing ? Any help would be greatly appreciated.
Old Jan 14, 2009 | 02:01 PM
carnut's Avatar
Default RE: 92 seville
Start with the basics. Verify correct, in spec, fuel pressure with a gauge, then check for spark to the plugs, then report back.
Old Jan 14, 2009 | 08:08 PM
Check for codes. Ignition timing? Distributor has to be oriented correctly or injectors will trigger at wrong time. Also check for spark at atleast 2 wires with spark tester. Check grounds at alternator bracket and bracket at starter.
