1992 Seville 4.9
Old Feb 16, 2008 | 08:46 PM
Tater50's Avatar
Default 1992 Seville 4.9
After warming up; while driving; when letting off accelerator, the RPMS stay up & descend very slowly; steadily pulling; vehicles has been sitting for 2 years, 97,000 original miles. Any ideas?
Old Feb 17, 2008 | 12:36 PM
bmesa1972's Avatar
Default RE: 1992 Seville 4.9
sounds to me that this vehicle is in need of a tune up I had similar problem with my 92 and after the tuneup it was running better
Old Feb 20, 2008 | 05:37 AM
Lithorian's Avatar
my 95 deville does it too, but not horribly, my ISC motor causes that
Old Feb 20, 2008 | 06:23 PM
Condition is called sail on. Make sure throttle plate and bore is clean of carbon. Re-learn TPS and idle. See if that correct condition.
Old Feb 23, 2008 | 09:47 PM
Tater50's Avatar
slowroll: you lost me; I am familiar with the old school vehicles, but modern stuff, I am lost.
I will look in the repair manual to see what that is.
Would carb cleaner clear up the problem if sprayed in that vicinity?
Old Feb 24, 2008 | 08:27 AM
4.1-4.9l pfi and 93-95 northstar engines have learned tps and idle. "SAIL ON" is when car wont slow down when throttle is released. It will be caused when PCM loses 12v (KAM) either from dead battery or disconnecting battery or PCM. Or if min air rate/tps is out of adjustment. Northstar has extra steps. Refer to the following thread
http://www.cadillacforum.com/m_18624..._2/key_/tm.htm
Request TSBs T93-44 and 31-60-06A from local dealer they pertain to this concern.
Old Feb 24, 2008 | 07:59 PM
Tater50's Avatar
I noticed that the ISC motor delays the accelerator from returning to the idle position. It returns in increments of 1/16" causing the RPMs to stay high.
Slowroll: could the ISC be the problem or would the carbon build up cause the ISC from closing up.
Thanks Tater
giuseppe
Jun 20, 2007 12:52 PM
ro9beam2002
Mar 26, 2007 06:41 PM
ro9beam2002
Mar 21, 2007 10:00 PM
wykid1
Apr 6, 2006 02:57 PM
wheeler34man
Jun 5, 2005 09:39 PM
