Re-programming radio and setting clock issue
I am considering a purchase of a 1991 Allante. The owner told me the battery was removed for two days and then replaced with a new battery. Since that time, the clock and the radio do not work. (I think the clock just needs to be re-set, but the radio is not working since the removal of the battery.) Is this an easy repair/re-setting, or will I have to visit a dealer to repair the clock and radio? I appreciate your help! Thanks!
Originally Posted by theatreman
(Post 30363)
No dealer needed to set the clock .. easy to do .. the instructions are in the OWNER's Manual. now .. what do you mean by "clock and radio do not work" .. the removal of a battery should have no effect other than losing the settings, stations, that sort of thing. they should work. if no sound comes out, the problem is not the battery. it is a BOSE system and repairs can go from $50 to $500. need more details ... . |
Update
Car is three states away. I don't have access to the owner's manual at this time.
The owner states the radio worked fine before he had the battery replaced. I have asked for more details -- does radio turn on, provide sound, etc. I'll post with the information. Thanks |
