Cadillac Allante and Allanté XYZ facts ...
Old Jun 12, 2021 | 01:57 PM
  #11
Writer222's Avatar
Default Is there a video on this?
Originally Posted by Stealth
TOP PULL DOWN - gear stripped, plastic gear housing cracked? a trunk pull down from the same era sedan or Eldo and swap the metal latch assembly to the plastic housing and gear assembly of the donor car. The only thing specifically different on a top pull down is the latch and trigger switch behind it. ~carnut
I found a pull down assembly that doesn't operate. Is there a video or step by step instruction for replacing the motor?
  #12
Writer222's Avatar
Old Apr 25, 2023 | 05:44 PM
  #13
Writer222's Avatar
Thanks Guys, I did find a broken pull down motor on eBay, then a replacement plastic housing, and rebuilt it myself. The real trick was in getting the pull down and release settings adjusted. When I have the hard top removed, the soft top works perfectly. but the hard top is missing a "J hook" that engages with the pull down motor. Anybody know where I can find one, or make one myself? As it is now the hardtop doesn't seat firmly, and rattles.
Cadillac Allante FAQ
May 27, 2013 12:44 AM
The Allante Pub
Apr 4, 2008 02:48 PM
Dec 1, 2007 01:46 PM
flatfoot56
Nov 27, 2007 09:49 PM
