MOLDY SMELL?
I have a 2002 escalade, and I notice every time after it's been in the rain, the next day it seems to have a moldy smell?
Any ideas or has anyone else had this problem?
It eventually goes away but it sucks!
Any suggestions will help!
Thanks,
Thanks,
ORIGINAL: skyhighent
Thanks,
Thanks,
read: https://www.cadillacforum.com/m_9792/tm.htm
Very nasty stuff on your health as well as you car. After a rain try to finda place that your window or door weatherstripping has been letting water seep in. You should see water tracks or latent water droplets. Generally it's a split or crack in the rubber mouldings somewhere. Go over all the carpetted areas with your hand to pick up any sign of wetness. Good luck on that.
yeh, I can't find any water or wetness on the interior anywhere. It's hard to pinpoint where it's actually coming from.
That's why I was checking to see if anyone has had the same problem and found out where or what it actually was.
It doesn't happen when I wash the truck or a light rain. Only when it's really heavy.
Thanks for the replies so far.
see if you can pin-point from where the smell is strongest.....front, back, drv.side, pass.side.etc..... imo. check around the back area. water is weird, it can travel a ways and end up not even close to where it comes in... by the way it sounds, you have quit a leak, somewhere....keep the Forum posted as to your progress, please..... and welcome to the Forum. hope we can help
