daytime running lights
Open the hood. Then take the black piece off that has the belt sticker on it. Use a screw driver to pull out the plugs. Then look at the headlight assembly. There are two pins in the headlight that hold it to the car. One of them if horizontal near the grill and the other is vertical on the top of the light. Pull them out and then wiggle the light loose. Be careful, but it does take some force. Then all you have to do is pull the rubber piece off behind the bulb that you want to change and change it. I had to replace arunning light the other day. Hope that this helps.
