slowroll |
05-10-2017 02:12 PM |
It is more how much do you want to spend? You won't know for sure what you got until engine is apart. Depending on how hot engine got will determine if block needs "time serts" It is also possible the "time serts' can pull when is reassembled. There are some who "time sert" all northstars when head is removed. There were some modified head bolts or studs not made by GM a few years ago. IDK if they still are. A used guarantied engine could be a cost effective repair; provided engine has at least 3 mo/ 3k mi P&L warranty. Reman will have more warranty, and may also pay labor. With Reman you want a repatable company with minimal BS if repairs are needed during the warranty period. GM and Jasper are easy to deal with. Jasper has a install kit which has hoses and belts, thermostat...etc which reduces breakdown after engine is installed. Reman engine itself doesn't include all the different maintenance items, they would be transferred from old engine. You woulkd also want to adjust your insurance for the several thousands of dollars spent on repairs also if get a loan to pay for repairs have extra money for repairs that maybe required shortly after reman install. It's a 20 year old car ...things happen. You don't want to be broke if you need the brakes fixed, window stops working, etc. Head gasket in a can should be a strictly a fix to trade, buyer beware with private parties can vary from state. So if you choose to go that route you will want as-is wording and witnessed. The rules are different when trading car to a car dealer, there is no expectation car is 100%.
