1967-70 FWD Eldorado engine/trans mounts
Old Jul 7, 2025 | 08:48 AM
jracer1966's Avatar
Default 1967-70 FWD Eldorado engine/trans mounts
Anyone have any luck sourcing these or a service to rebuild? I am getting quotes for $550 + shipping (both ways). I was really hoping I could just buy some replacements.
Old Jul 10, 2025 | 01:59 AM
Schurkey's Avatar
Revulcanizing original mounts: Hatefully expensive.
https://www.steelerubber.com/motor-m...ice-60-0624-11
Autozone claims this fits a '69 ElDo.
Duralast Motor Mount 2296
https://www.autozone.com/external-engine/motor-mount
or O'Reillys "Power Torque B2296"
https://www.oreillyauto.com/detail/c...ne+mount&pos=0
Which probably means an "Anchor" brand 2296 would also fit.
I'm thinking you need two transmission mounts, and one engine mount? I know that things changed over time.
Old Jul 10, 2025 | 10:40 AM
jracer1966's Avatar
Thanks for the info. I will pluck my mounts, see if I can cross mate them with anything offered on the web first off. If not, I have a $550 effort lined up to update my existing. Fingers crossed...
Old Jul 10, 2025 | 01:30 PM
Schurkey's Avatar
I have the sense that there's more than one style of these mounts depending on the year of production. One assumes that the rear "transmission" mounts would be the same as Olds Toro of the same model year. The front mount may or may not be the same as Olds Toro.
Consider grabbing mounts from the Treasure Yard that match the ones you have, and either use them as-is if they're in better condition than yours, or send off the Treasure-yard mounts for rebuilding so you don't have to disturb your engine during the weeks it takes to get them rebuilt.
There's also the slim chance you can fabricate an acceptable set of mounts from some other vehicle--perhaps RWD transmission mounts would be close.
rustedorrotting
Sep 25, 2022 01:40 PM
kickasscadillac
Automatic Transmissions
Apr 8, 2017 04:13 PM
CoupeDevilln
Feb 5, 2007 04:03 AM
gunkscad
Dec 4, 2006 02:14 PM
edtherock
Dec 9, 2005 03:04 AM
