View Poll Results: DTS 2006 no crank replaced the starter ran great for one day now no crank
Ignition switch problems
0%
Neutral switch problems
0%
Crank relay possibly bad
0%
Voters: 0. You may not vote on this poll
2006 DTS no crank
Old Jul 15, 2020 | 10:05 AM
Gtr420est's Avatar
Default 2006 DTS no crank
2006 DTS no crank. I replaced starter ran great for one day then no crank. I have been having trouble when turning off the car the ignition won't turn off all the way would have to re insert it into Park to remove ignition key. No error codes no security codes on dashboard could this be due to faulty ignition?
Old Jul 15, 2020 | 11:04 AM
dtcassist's Avatar
Former Sponsor
There are unfortunately many more possibilities to what could be wrong, but from what you are saying about having trouble getting the key out, I would first suspect an issue involving the shift cable or transmission. Watch the PRNDL when trying to start - you may be not fully engaged in Park and the car thinks you are in gear, so not letting you crank the engine.
DoctorAllcome
Mar 10, 2022 06:55 PM
sts1084
Jul 18, 2019 09:16 PM
DSawyer
May 14, 2017 11:28 AM
dtsjoe
Jun 21, 2015 06:04 PM
profking
Nov 23, 2012 04:39 PM
