need help about suspension on 02 deville
Old Jun 22, 2010 | 06:10 PM
c.camp450's Avatar
Unhappy need help about suspension on 02 deville
hi i just purchased 02 deville and every bump i hit it the rear bounces up and down, now i dont know if it has air ride or what. can someone please tell me what could be causing this and what i should replace? when its sitting still it looks pretty level, its not drooping in the rear so i dont know, this ismy first cadillac so im kinda clueless about it. thank you any info is greatly appreciated!! also if its the air ride i would like to purchase a non-air conversion kit. so i need to know everything i need to fix the problem...thanks!
Old Jan 13, 2013 | 11:37 AM
lickskellet48's Avatar
Default Had similiar experience on 2000 deville rear shocks
It rode like a log wagon and dealer could not find problem without running expensive scan. Found problem myself by heating up shocks with heat gun. Problem was due to extreme cold temptures causing the moisture that in shocks frooze until the evening tempertures thawed out shocks. Air dryer was not working taking out moisture allowing condensate build up. Removed shocks and compressed pushing water out but damage caused resulted replacing them with a set of used ones found on line salvage.
Old Feb 3, 2013 | 06:18 PM
SimpsonTruckDriver's Avatar
Correct. The bouncy shocks mean they are bad. Here is how you test: Push down on the bumper and release. If it goes up and stops, the shocks are fine. If it goes up-down-up, they need to be replaced. Even if it wiggles (small up-down-up), they're still bad. You can buy new OEM ones, or get higher quality aftermarket (like MONROE) ones, either ones will work. I would NOT suggest junkyard ones. Once they are installed, have a mechanic do a wheel alignment, and the ride will be better!
TS
Gregg Reed
Apr 13, 2014 09:09 PM
deez
Jul 21, 2010 11:35 AM
touringsedan
Apr 22, 2008 07:27 PM
cadillactt
Mar 12, 2008 01:31 AM
ajax68960
Jan 25, 2008 08:17 PM
