I TURN THE KEY AND GET NOTHING
Old Jul 23, 2008 | 06:53 PM
97winger's Avatar
Default I TURN THE KEY AND GET NOTHING
I have a 99 deville with 86K .It hadn't been started in a few week so I when to start it and the battery was low so I jump it and it fired right up then took it around the block and got back turn it off and it would not turn over again,Put the changer on it for 12 hours and now .....turn the key and get nothing no click no nothing. Battery up and holding change, cleaned the cables and all connection I could find ,tried spare key wiggling up & down try it in neutral .Its not throwing a code, disconnected aftermarket stereo and I was just about to jump the started when the rains came. If anyone has any ideas I would appreciate it Thanks
Old Jul 24, 2008 | 08:53 AM
Katzmans Caddy's Avatar
Default RE: I TURN THE KEY AND GET NOTHING
You have done pretty much what I would have suggested. I still think you have a bad ground though.
Old Jul 24, 2008 | 04:59 PM
97winger's Avatar
Thanks, I will double check the grounds do you think it could be the starter solenoid?
Old Jul 24, 2008 | 05:06 PM
The car started and drove, have a good look at the ground then let us know.
Old Jul 24, 2008 | 06:07 PM
thewood's Avatar
Are you sure the battery charged? Did you test it after you charged it?
Old Jul 24, 2008 | 06:50 PM
97winger's Avatar
Just when out put the battery ,disconnected - cable, wire wheel all ends ,did not help: battery is holding 12.5 amps which way would I attack the starter top or bottom ,I assume its driver side front
Old Jul 24, 2008 | 08:11 PM
Starter is under intake manifold. There is a connector at front of rear valve cover, you could check for voltage there before pulling manifold. If pulling manifold check condition of rubber boot at front intake before re-installing, they tend to develope a hole which will lead to SES light and idle concerns.
Old Jul 24, 2008 | 08:26 PM
97winger's Avatar
Thanks slowroll , I'm going to jump on that tomorrow after work
Old Sep 21, 2008 | 09:53 PM
97winger's Avatar
After all of that it was the starter,the solenoid must have been sticking ,once I got it out and tested it, it worked ,put it back in and it turned over. I put in a new one in anyways seeing what you have to do to get to it THANKS TO ALL!
Old Sep 22, 2008 | 09:27 AM
You have big ones for tackling that job, way to go!
shackallic
Cadillac EXT
Mar 5, 2014 07:30 AM
cooleric2000
Aug 4, 2010 08:27 AM
carl.r.johnson
Sep 18, 2007 01:46 PM
Aquit45
Jul 16, 2006 12:58 AM
