help
i have a 1997 cadillac deville, and when i drive it for awhile, and stop my oil light flashes what is going on. i had it checked out but they could find out whats wrong. someone please help.
RE: help
what other symptoms does your car get?
RE: help
there can be several causes. one may be the oil pump. or a worn out rod bearing, or a faulty oil pressure sending unit. you can start by checking some of those parts.
RE: help
if you got some replacement jobs,or if you need some parts for your problem there's one place i could suggest. try partstrain and look up some engine parts or a new sending unit maybe.
RE: help
Funny......I am going thru the same thing now with my 97 deville cocncurs, the light would flash on ocassion at idle, the oil was normally 1 to 2 quarts low. now the light sometimes stays on steady and i get the chiming AND THE stop engine low oil pressure.
NOW THE OIL LEVEL IS FINE! i took the cap off the uses a flashlight ot make sure oil was circulating, i checked the dip stick while the motor was running to and it was full up the stick. most likely its the oil pressure sensor, the same thing happened on a 200 auora my pops owned. im pretty sure the sensor is located on top of the motor just obve the oil cap, i hit mine a few times witha hammer and its been working fine since. i really would not worry |
