help
RE: help
if you got some replacement jobs,or if you need some parts for your problem there's one place i could suggest. try partstrain and look up some engine parts or a new sending unit maybe.
RE: help
Funny......I am going thru the same thing now with my 97 deville cocncurs, the light would flash on ocassion at idle, the oil was normally 1 to 2 quarts low. now the light sometimes stays on steady and i get the chiming AND THE stop engine low oil pressure.
NOW THE OIL LEVEL IS FINE! i took the cap off the uses a flashlight ot make sure oil was circulating, i checked the dip stick while the motor was running to and it was full up the stick. most likely its the oil pressure sensor, the same thing happened on a 200 auora my pops owned. im pretty sure the sensor is located on top of the motor just obve the oil cap, i hit mine a few times witha hammer and its been working fine since. i really would not worry
