'96 parts fit on a '98?
Old Nov 17, 2013 | 03:13 PM
Buddinator's Avatar
Default '96 parts fit on a '98?
Hey Caddy fans. My '98 Deville Concours needs rotors, tires and rims. All my rims leak. Tire shop couldn't even keep air in them. So anyway, I found a '96 Deville with new brakes and tires on good rims for a good price. I just need to know if those '96 rotors and rims will fit on my '98. Thanks.
Old Nov 18, 2013 | 01:53 AM
Serina33's Avatar
I like the tip. Thanks to post it here.. I agree with the suggestion and will follow this...
Old Nov 18, 2013 | 09:53 AM
SimpsonTruckDriver's Avatar
From what I know, brake rotors are standard on most identical models. But, if you wanted to put 2000 brakes on a 1998, it MIGHT NOT work. Seeing as the 1996 and 1998 models are very close, I see no reason why they wouldn't fit. In terms of wheels, you can put whatever you want on them! You can put OEM on them, or you can upgrade to hundreds of styles, maybe even upgrade to a larger wheel (wheel dealers would be able to assist in getting the right tire/wheel size that won't affect speed or handling).
TS
Old Nov 19, 2013 | 06:19 PM
Buddinator's Avatar
Well the 97 to 99 are identical. The 96 is not. That is why I'm curious. This 96 I'm eyeballing has new tires, new rotors and pads and a bunch of new stuff. It would be perfect for me. If I knew for sure that everything would just bolt on to my 98 I'd buy it but I don't want to buy it and then find out nothing fits.
bdpuppy
Apr 15, 2018 01:24 PM
jmspradl
Jun 25, 2007 06:26 PM
1983 mocha
Apr 9, 2007 01:31 PM
G.A.R.Y.
Mar 9, 2007 10:06 PM
medicz28
Feb 6, 2006 03:11 AM
