87 Deville Has Fuel Pressure to the TBI But Injectors Won't Activate
Friends, my 1987 Deville has a new fuel pump, filter and pressure regulator. Fuel Pressure does reach the TBI But the injectors won't release any fuel. The engine will start and continue to run for a couple of seconds if a bit of gas is poured down the TBI throat.
Please give me a list of things to check and how to check them. My mechanical experience is community college automotive courses back in the early eighties and a few dozen fixer uppers. My diagnostic capabilities sux but I have an excellent understanding of electro/mechanical principals, including electronics and digital logic. Please help me Obiwan, you're my only hope. PERTINENT INFORMATION I FORGOT TO ADD I am actually starting this for my nephew, the car ran then didn't run after an alternator swap. there is a brown wire with a green end with the alternator wires that I cannot tell where it goes. Someone else took the alternator off. To me it's a basket case, I am finishing someone's job. |
Is the 12 volts to injector connectors, ECM grounds injectors to spray fuel. Codes ? FAQ has info about on-board diagnostics. don't worry with green connector. Ground wires need to be attached, fastener needs to paint/rust free. DFI is ground sensitive, unique to Cadillac so it can not be treated like a chevy. Ground wire issue would follow alt replacement no start. 4 wire distributor connector needs to be connected. Ignition system is typical GM HEI, reference signal sent to ecm to trigger injectors.
Originally Posted by slowroll
(Post 47690)
About the 4 wire distributor connector, I would say that they are connected if the engine start when gas is poured down the TBI throat but I am going to check it anyway. SlowRoll, what's next? By the way, where is the ECM? |
A voltmeter will indicate if you have voltage to injector connector. Injector fuse is under right side of dash. 4 wire connector is more about fuel injection than spark. purple wire in 4 wire connector carries reference signal to ecm to turn on injector. If you take a test light attach ground connector to positive battery terminal so it looks for ground. With key on touch probe to purple wire on engine harness side of 4 wire connector. when probe is removed you should hear injector(S) click or noid light if you have one will blink. No click or blink ecm would be suspect, click or blink would be ignition module. Ecm is under right side of dash you should see it when under dash or hush panel is removed. If the plan is to keep car you will need FSM, you need to know how to use the on-board diagnostics beyond getting and clearing codes. Oil pressure switch connector has a habit of melting and shorting out fuel pump fuel pressure 9-15 psi.
(Post 47712)
About the four wire connector on the distributor, are you saying to disconnect or back probe it while it's connected? OnBoard diagnostics does not display any codes, could that be because there wasn't a battery in it for a year? On my Sierra disconnecting the battery clears the codes. |
yes disconnect 4 wire test body side. with injectors plugged in.
