1991 Cadillac Deville to Laptop?
Old Feb 5, 2006 | 06:19 PM
onecool's Avatar
Default 1991 Cadillac Deville to Laptop?
Ok I have a 1991 Cadillac Deville with digital dash I fond the ALDL I bought a hookup up and tried different things but cant get it to work?
It’s weird the ALDL only has A, B and K, L, M wires are A= black with a white stripe, B=white with a black stripe, K=Purple, L=thin tan wire, M=think tan wire.
Is this ODB1 or 2 I think 1.
What connetor should use?
Is it 160 BAUD or is it the 8192?
Do I use a jumper on A to B or do I use a 10k resister?
Any help would be Grate.
A = Black with a White strip
B = White with a Black stripe
--| F | E | D | C | B | A |--
--| G | H | J | K | L | M |--
K = Purple
L = Thin Tan wire
M = Thick Tan wire
ps: I know I can use the climent control panle but i would love to see the read out on the laptop.
Old Jul 14, 2006 | 07:17 AM
Adrian12's Avatar
Default RE: 1991 Cadillac Deville to Laptop?
hi!
I've the same problem with an 1981 deville but I've a solution, that may works with your caddy.
http://winaldl.joby.se/aldlcable.htm
I've built that cable with the +12V from the serial port!
This is an 160 baud connector and maybe it works with your caddy!
I use TunerProRT as software with a definition.
Ask for a definition at http://forum.tunerpro.net/
The 10k Ohm resister is a good question, try without it and if it doesn't work, try with it!
I hope I could help you a little!
imhottt1971
Jun 4, 2008 11:14 AM
cob
Aug 3, 2007 05:54 PM
CrusinCaddy83
Jul 10, 2007 12:39 PM
cob
Dec 4, 2006 12:15 AM
Roadhack
Feb 12, 2005 11:09 PM
