Steve Hanson |
06-23-2019 08:58 PM |
01 Deville instrument cluster, HVAC display dark
I have searched and searched for help on this problem. 2001 Cadillac Deville
About a year ago, my instrument cluster and HVAC controls went dark. About a day later they were back on and never turned off again...until last Friday. This time they did not come back on. I was turning the ignition on/off a few times to check a brake fluid sensor warning message (to see if I corrected the problem replacing the sensor on the brake reservoir that was giving me problems) and suddenly the Attempted Theft warning came on the dash. Then everything went dark. I have checked all fuses, and swapped some relays in both fuse boxes to see if I could find the problem. No such luck. Today my digital dash is dark and HVAC is also dark yet everything is working fine. I went to a dealership and they thought it may be the ignition module and stated that they would recommend replacing that first so they have a place to start troubleshooting from. I do not think it is the ignition module but I ordered a new one which will be here in a few days. This absolutely baffles me since everything was working fine prior and all digital gauges on both displays were working fine prior to Friday. I have been reading lots and lots of posts on individuals who had similar type issues. No solutions. I have also done the battery disconnect/hard reset touch red and black together to drain computers. etc. for several minutes also...didn't work. Need help solving this one please.
