wheel spacers
I'm looking to add wheel spacers to bring the tires close to flush to the fenders and am curious on the sizes. It looks like it'll be around 15mm for the back and 10mm for the front. My question is will this fairly small thickness of spacer require the cutting of the studs on the stock hub before I can fit the wheel back on? I've used spacers a couple times before and after putting the hub centric spacers on the wheel bolted right up without needing to cut anything. Thanks for the help!
Ben
Ben
