Oil Filter Location
Old May 11, 2009 | 04:40 PM
niki08's Avatar
Default Oil Filter Location
Where is the oil filter located on a 2008 CTS with the base engine? Is the filter easily assessable?
Old May 11, 2009 | 07:44 PM
Underdog's Avatar
Well, on an 05 with the 3.6 V-6 it is accessable from under the hood, on the drivers side next to the engine cover. Its a small aluminum cylinder with a 24 mm hex head cover. You unscrew the cover, remove and replace the filter element and screw the cover back on. I believe the 2.8 L engine is the same.
Old May 12, 2009 | 12:28 PM
niki08's Avatar
Found the filter in the engine compartment as you described. Thanks.
Texan4Life
Feb 10, 2010 07:12 PM
SHARKCRAZY
Jun 9, 2009 10:58 AM
mechanical man
Mar 1, 2009 05:36 PM
chrissirwin
Nov 1, 2008 09:04 PM
barry6321
Apr 23, 2007 12:46 PM
