"Service steering system"
Old Jun 12, 2006 | 11:38 AM
markboyd's Avatar
Default "Service steering system"
In my '03 CTS I'm getting the message "Service steering system" on the operator screen (Navigation screen in my case)
I've done an OBD scan and I'm not seeing any error codes, although I'm not totally confident in the scan tool in conjunction with the OBD system in the CTS.
Anyone seen this? What parameter is this system seeing out of spec that would cause this message?
Thanks a bunch!
MB
Old Jun 12, 2006 | 07:26 PM
markboyd's Avatar
Default RE: "Service steering system"
I think I found the answer... more than likely the "Variable Effort Steering (VES) Solenoid"
A tech note is available here => http://www.cadillacfaq.com/faq/tsb/index.php?category=4
Old Jun 12, 2006 | 09:15 PM
ctsv8's Avatar
more likely the hand wheel speed sensor located on the steering column. This device measures steering wheel movement. It is a circular looking sensor which the steering column shaft goes through it. You will need to have a Tech 2 or some other type of scanner to check this one out.
BE
SRXer
Jul 20, 2011 10:07 PM
tombeiter
May 24, 2007 05:06 PM
