70 Deville fuel pump Q’s
Old 03-20-2019, 04:54 PM
Deville Dog's Avatar
Default 70 Deville fuel pump Q’s
Replaced my fuel pump. Most likely orig. had one 3/8” port and one threaded feed . New pump has a 2nd port hanging off that is 1/4”. Noticed when i ran new fuel line that there is another pick up on the tank. Did there used to be a fuel return on these beasts back in the day? Am i OK to cap off the Additional port or run a return?
Old 10-13-2021, 09:21 AM
TomSchaeffer's Avatar
Hi! I am not sure about it, but I think that you need to check the vehicle history before and you will find out..
Old 11-28-2021, 03:46 PM
Zx600e93's Avatar
Default Same boat haha
I believe that's the return line that goes back to the fuel tank, I've cleaned both lines out, replace all fuel hoses, and test the fuel pump for our recent buy a 70' Coupe Deville 😀
eight_05_south
07-17-2009 08:22 AM
hunter01000
02-18-2007 02:32 PM
Adrian12
11-01-2006 04:11 PM
David
08-04-2006 11:27 PM
David
08-03-2006 03:25 PM
Quick Reply: 70 Deville fuel pump Q’s
