2002 deville - brake help
I have a 2002 Deville JL9 braking system. The front brakes began pulsating when applied.
Replaced front rotors and pads... same problem.
replaced calipers and no firm pedal after bleeding over and over...
pedal is firm with engine off when the engine is on the pedal creeps to the floor.
Replaced master cylinder and front hoses also.
note.. Rear pads and rotors are new....
I have read about the possibility of the need to bleed to ABS and that this may need to be by the dealer.. How do I know if this is the case.
Any other suggestions....
madmax123
Sep 2, 2013 02:08 PM
99STSGUY
Jan 21, 2009 08:29 AM
