2000 DTS ABS and Traction Control
Old Nov 26, 2007 | 09:35 PM
swisc's Avatar
Default 2000 DTS ABS and Traction Control
The ABS and Traction Control dashboard lights just lit up on my 2000 DTS which has 154k miles. The "Service Stability Control System" message is also showing in the Information Center. Are there any steps I can take to trouble shoot this on my own, or does it need to go to a shop to be scanned for specific codes etc.?
The front rotors and front brake pads were replaced 3 days ago. Could that have something to do with these indicator lights coming on now? They've never come on in the past.
Old Nov 26, 2007 | 10:19 PM
Default RE: 2000 DTS ABS and Traction Control
You need to find what code(s) stored for guidence.
Old Sep 10, 2008 | 01:02 AM
dhaddad84's Avatar
Not 100% sure but my friend is a mechanic, and I had... well have the same issue with my 02 Deville. ABS, Traction Control, and Brake lights light up and stay on... he just saw those 3 lights and told me it wasa speed sensor. The funny part is my trusted mechanic said the same thing but could not determine which one ($peed sensor is $300 to $400 bucks a pop and I can't afford to start replacing random expe$ive parts. Unfortunatly the Cadillac dealership by my house went out of business. Don't know what good that would do for me. Good luck.
Old Oct 11, 2008 | 03:09 AM
groce45's Avatar
my wifes 97 reviera does the same thing, been on for a year,
Old Oct 11, 2008 | 01:06 PM
derrickwi's Avatar
I have the same model and had exactly the same problem but it was intermittent. Also had a stabitliy control message. One day the brake lights failed to work as well and the brake light switch was replaced. The ABS and traction lights and message never came on again. The brake light switch is easy to replace its next to the brake pedal. Next time I will do it myself.
This may not be your problem but its easy to replace the brake switch.
vrathbone
Jun 29, 2010 06:47 AM
shadmaster3
Aug 4, 2009 12:14 PM
black99
Feb 11, 2008 07:18 PM
cleancaddy
Nov 25, 2007 12:25 AM
OldBikeDad
Jan 13, 2007 08:37 PM
