1989 deville stuck caliper
Old Feb 14, 2009 | 08:24 AM
DONMANCHESTER's Avatar
Default 1989 deville stuck caliper
I recently changed both Calipers and Pads on a 1989 Cadillac Deville because the front Passengers side Caliper appeared to be stuck. After Changing and bleeding lines and checking for kinks in the brake lines I took it for a test ride only to find out I still had the same problem. He front right side pad was sticking and smoking. Could this be a Master cylinder problem? Any help would be appreciated.
Old Feb 14, 2009 | 09:25 PM
Master cylinder - no. Brake hose highly possible, problem within caliper or abs valve block are also possible.
Old Feb 15, 2009 | 06:28 PM
carnut's Avatar
I agree, usually a restricted hose to the sticky caliper. If true, replace both front hoses.
1989 fleetwood
Sep 2, 2014 01:48 AM
Jayson
Nov 6, 2008 06:40 PM
NOGUTSNOGLORY
Nov 30, 2007 10:06 PM
DieselDemon
Nov 29, 2006 08:57 PM
Oishi
Mar 13, 2006 04:29 AM
