Aluminum Block V8s
matching 'Y" vin codes
Aluminum Block V8s
4.1, 4.5, 4.6, and 4.9 liter engines.
Mar 7, 2010 | 10:32 AM
phinfan1376
Mar 2010
Will drive train out of a 99 deville work in a 96 deville. if so which pcm should i use and which wire harness
phinfan1376
Find all posts by phinfan1376
Mar 7, 2010 | 01:48 PM
slowroll
Oct 2007
in the mitten
engine will, not sure about trans.
slowroll
Send a private message to slowroll
Find all posts by slowroll
Mar 8, 2010 | 02:24 AM
phinfan1376
Mar 2010
What pcm should I use?
phinfan1376
Clearing "pending codes" on DCM will remove error code 0741???
phoretwan
08:49 AM
2005 Deville "Jerking" and "Bucking" problem
missileJ
May 8, 2012
01:28 PM
Matching numbers
lou19604
07:44 PM
"Speed limited to 90mph" & "Service Suspension" Error
bsstyle2011
04:07 PM
window glass matching years
squidfoot
11:40 AM
Tags
cadillac
code
match
vin
Aluminum Block V8s
ISC RPM out of range
06:52 AM
