Gasket Set?
Old May 29, 2008 | 04:16 PM
Dave S Texas's Avatar
Default Gasket Set?
A project I've put-off for too long is, curing an oil-leak around the timing-cover area. I think everything can be done from the RH wheel-well...right? I've shopped for gaskets and I'm asking if the Conversion-Set is what I need and does it contain all the gaskets/seals I need? Is the old Indian Head brand sealant sufficient? Also: while I'm at it, can the oil-pan gasket be replaced with the engine still in the engine-bay? Thanks for any help/info/advice, I appreciate it very much.
scracer23
Oct 4, 2007 12:08 PM
peterock29
Jun 25, 2007 06:09 PM
DinkyDink
Mar 15, 2007 10:06 PM
amv50
Nov 2, 2006 02:38 PM
