codes
Old Mar 28, 2009 | 03:49 PM
olboy2010's Avatar
Default codes
hello. new caddy owner here. i have several codes for my car. whoever had it before me did a lot of wire cutting. just wondered if someone could help me understand these codes and let me kno if i should clear them out or take it in for repair. here are the codes. o its a 99 deville.
U1016, 1040, 1064, 1088, 1255. B1552, 1910, 1983. P0603, 0741. yea its a lot. someone please help me!!!! thanks
Old Mar 28, 2009 | 09:22 PM
id clear codes, and drive for a day or so and then recheck codes. is the car not running right? let the forum know
Old Apr 1, 2009 | 03:43 PM
olboy2010's Avatar
Default thanks
thanks. i cleared the codes. the only codes that show now are. p0741 and u1255. will i b able to do a tuneup myself or shall i take it to the pros??
Old Apr 1, 2009 | 06:22 PM
P0741 is trans concern u1255 - Data fault - cut up wiring - not good - think you may need the Pros. If you have done tune ups before you should be ok
Old Apr 16, 2009 | 07:55 PM
olboy2010's Avatar
Default fine tuning
thanks guys for all your help. i'll b buggin u all for a while. i heard there is a k & n air filter that will fit in the deville. does anyone kno the part number. also does anyone know if it is ok to use those platinum plus spark plugs (the ones u dont have to gap) or should i stick with the old school plugs?? thanks a mil!!!!
Old Apr 16, 2009 | 09:02 PM
olboy2010's Avatar
Default im back
hey guys. i have a set of 16" Vogue X'Cess rims. I need one more to use as a spare but im catching h**l trying to find one. anyone know any websites or rim shops that might carry them. Pllllllleeeeezzzzzzzzzeeeeeeee help!!! thanks.
dfb52764
Aluminum Block V8s
Jan 11, 2009 09:50 PM
