94 deville subs
I have a 94 concours with the stock radio still. All I want to do is add a single ten with a amp into the system to boost my bass. How would i go about plugging the amp into the system since there are no RCA inputs in the actual head unit? I know how to set my amp up and how to connect the wires to power it, i am just having troubles with figuring out how im gonna get the amp into the whole system. any elp is greatly appreciated
RE: 94 deville subs
You're probably going to need an aftermarket sterio. It's what I'm doing on mine in a few days.
RE: 94 deville subs
actually I figured it out with the help of wuite a few people.
All I needed was one little adapter that cost me $20 and the normal wiring and I was set. Its called a Line Output Converter, or LOC. Its also called a Hi-Lo RCA adapter at other places. Pretty much it just splices into the wires from your 6X9's and converts it into something your amp can hook up to. I did it so I can keep the tape deck. I have an adapter that makes it so i can hook any device with a headphone jack up to my stereo throughthe tape deck. and all I use is my zune so i figured why waste hundreds of dollars for something that cost me $20 to do with the equipment I already had. |
RE: 94 deville subs
ORIGINAL: cadillaczak actually I figured it out with the help of wuite a few people. All I needed was one little adapter that cost me $20 and the normal wiring and I was set. Its called a Line Output Converter, or LOC. Its also called a Hi-Lo RCA adapter at other places. Pretty much it just splices into the wires from your 6X9's and converts it into something your amp can hook up to. I did it so I can keep the tape deck. I have an adapter that makes it so i can hook any device with a headphone jack up to my stereo throughthe tape deck. and all I use is my zune so i figured why waste hundreds of dollars for something that cost me $20 to do with the equipment I already had. good info .. economical solution. I believe that what you got takes the standard freq and extracts the low frequencies that the BASS-AMP needs. My car came with a after market AM/FM/CD/DVD remote control made by BOSS ( not to be confused with BOSE ) The previous owner simply disconnected the OEM stereo, cut the wires that go to the speakers and wired those wires into the new system. New system using the OEM speakers ( I think). All I know, it plays everything I trow at it well. Should I ever want to watch a movie, I believe all I need is a LCD screen that plugs right into it. I was thinking of pulling it out, but Foxpaws disagreed and said "KEEP IT." for muti-media audio/video questions, this site can be very helpful: the moderators there are geniuses. http://www.acurazine.com/forums/arch....php/f-22.html |
RE: 94 deville subs
i can go with the LOC, but but it's recomened you go with the RCA cables. The sound quality is a lot worse with the LOC and it also doesn't come as good from your player to the deck. You might as well buy a 10 dollar harness and a 40 dollar CD player at Circuit City.
