Upper transmission line
Old 06-24-2016, 12:41 PM
David Peterson's Avatar
Default Upper transmission line
I am replacing your upper transmission line on my 2008 cadillac dts . I have it until bolted from the transmission but I can not get to the rear quick disconnect. Is there and special way I can take it off. Does anyone have a video . Thanks for ur help
Old 07-06-2016, 12:20 PM
once you move plastic collar away from nut you will need a pick type to to remove spring clip. The clip can jump far and quick so be prepared. Re-install clip in nut prior to installing line.
DTL
12-29-2015 07:26 PM
wrk907
11-13-2012 02:04 PM
top_speed1
04-10-2008 04:42 PM
matz445
12-12-2006 10:14 PM
xknowonex
03-19-2006 07:34 AM
Quick Reply: Upper transmission line
