Transmission troubles
Old 04-14-2015, 09:29 PM
Drewbishop's Avatar
Default Transmission troubles
I have a 2006 CTS. Recently while driving, the car is running at high rpm's and does not seem to want to switch gears. Then after coming to a stop it seems like the car switches into neutral. Now after not being run in a few days, when cranked the entire car shakes. I don't know if it's a gear, clutch, sensor, etc. issue. Please help. Thanks.
Old 05-02-2015, 07:32 AM
Adams' Apple's Avatar
Obviously something is not right. Definitely sounds like a trans problem, but you really need to have it scanned for codes to see what might be amiss. You will likely need to take it to a shop for repairs, regardless. Really need more info...
keithm
05-28-2017 03:05 PM
Caddy Wagon
05-13-2008 07:39 PM
digitalis77
03-28-2008 06:55 PM
buckshot1960
Aluminum Block V8s
10-06-2007 07:51 PM
JayR101
04-15-2007 10:08 PM
Quick Reply: Transmission troubles
