1999 Seville shock and strut replacement
I am wondering if anyone has had good luck with an aftermarket shock and strut replacement for Seville STS models with F45 and F3 suspension option., The factory replacements cost more than the car is worth but is the only problem with the car. I can't see scraping a good car because it need shocks.
You can go with ARNOTT for good OEM shocks and struts. You can also go with MONROE, which upgrades the suspension. I had the rear struts replaced on my former car - a 1999 Sedan Deville - with Monroes, and it rode PHENOMENAL!
TS
TS
Arnott Air Springs, Struts, and Coil Spring Conversion Kits detailed below are backed by a Limited Lifetime Warranty in North America and a Two-Year Limited Warranty in the rest of the world. Air Suspension Compressors are backed by a Two-Year Limited Warranty.
jimzilla
09-06-2008 06:00 AM
2001 DEVILLE MOAN IN TURNING AT SLOW SPEEDS, REAR SHOCK ADVISE HELP, AND VIBRATION AT HIGHWAY SPEEDS
jd3772001
07-12-2007 09:31 PM
