Non-V8 Engines 1 to 6 cyl Cadillac engines including the single cyl 1902 Leland 10hp engine.
Timing chains
Old 07-18-2016, 05:58 AM
koldinhell's Avatar
Default Timing chains
just replaced the chains on my 2008 srx at 145k everything went nice and smooth no issues car started right up...
issue is that chains now rattle at every cold start just like first start when tensioners were dry....starts right up runs perfectly after no noises or engine codes just drove to east coast 2500 mile trip no issues just the startup noise
any ideas why its doing this
everything is new
Old 07-18-2016, 01:32 PM
Did you replace tensioners and shoes/guides? It is possible oil is bleeding back; are using GM oil filter? If answers are both yes it is possible that "O"ring for oil pump pick up is compressed and allowing air to enter oil system when engine is cold. Once engine heats up the seal expands and it seals. You will need to remove oil pan to correct.
Old 07-19-2016, 01:11 AM
koldinhell's Avatar
Thanks for response and yes i did replace everything and do use GM oil filter...
the old chain and tensioners never rattled at all was just getting PO0008 code so i guess one of the tensioners is bleeding oil back after sitting so i guess ill have to take it all apart again
djlan99
Non-V8 Engines
12-04-2013 05:15 PM
cts09
02-01-2011 09:53 AM
hanselss13
01-07-2009 11:04 PM
bluestreak
03-11-2008 09:32 PM
matz445
01-04-2007 05:21 PM
Quick Reply: Timing chains
