Sponsored by:
Sponsored by:
Taillight problem
Old 08-21-2009, 07:40 PM
dipsetbitch's Avatar
Default Taillight problem
on my 96 deville my left tail light will not work. The bulbs are good and when i hit the brake the lights come on but if im not holding the brake they will not stay on. Does anyone know what this could be?
Old 08-22-2009, 10:56 AM
You could test for 12v on socket terminals, with bulbs removed, with voltmeter or test light. also check ground terminal which contacts side of bulb. Sometimes socket contacts will collapse which can cause lighting concerns also. Test with park lights and hazards on so all wires are powered up.
Old 08-22-2009, 06:33 PM
sorry i dont know much about cars... what is a socket terminal and a ground terminal?
Old 08-23-2009, 08:19 AM
????? I think you need to find someone locally to help you, post what you find, and the "forum" can still try to guide you. If you have no fundamental knowledge, getting an basic automotive text book (VoTech) maybe helpful.
Old 09-15-2009, 06:58 AM
i think all you need is a new bulb.... in that bulb there is two lights. the tail light is bad, and the brake is good..... change the bulb, if you can or ask for some help. its pretty simple. your owners manual might assist you with this
Old 09-19-2009, 07:39 PM
i already replaced the bulbs
Old 09-01-2011, 08:30 PM
Cromaglious's Avatar
Unhappy 97 deville left tail and left marker not working
On my 97 deville the left tail and left marker are not working. If I put on the right turn signal and short the left tail and right turn wires together at the trailer connector then I get a blinking left tail and marker. In the middle of the hidden inboard BIG fuse panel there is a 50amp fuse which will turn off the right marker and tail light. I haven't been able to find a blown fuse anywhere. I also haven't found a schematic for the light switch either. I've pulled all the relays and haven't found one that controls the right tail and marker either.
Do I need to order a service manual for my car to get the schematics?
JBeam4ME
06-17-2023 04:07 AM
Gaijin
02-08-2009 09:07 AM
girlfriday237
11-05-2008 08:10 AM
carnut
03-14-2008 06:01 PM
rorsino
11-25-2007 01:57 AM
Quick Reply: Taillight problem
