Sponsored by:
Sponsored by:
2005Cadillac Srx rumbling/grinding noise rear end!
Old 10-27-2011, 08:23 AM
spartanedw's Avatar
Default 2005Cadillac Srx rumbling/grinding noise rear end!
Hello I need some help here.. I've got a 2005 cadillac srx all wheel drive.. I have been having a rumbling/grinding noise in the rear end of the car.. Its not constant it happens between 45-60mph.. I cant seem to narrow it down.. Now here's the bad part this is a list of all the things I replaced Drive shafts, rear differential, rear differential bushings and cv shafts.. I've done the test for the rear wheel hubs but I dont have any play in the wheels.. I'm close to pulling my hair out here anybody else run across this problem and or have any other ideas?
Old 10-27-2011, 04:47 PM
etbracket's Avatar
Could be 2 things either a bearing or your tires. Check the wear on your tires. Run your hand on the tread and see if the tire feels choppy. As for a bearing noise does it change when you go around right or left corners?
Old 10-28-2011, 07:21 AM
spartanedw's Avatar
The tires have even tread and it does not make the sound when turning corners.. The sound occurs when traveling in a straight line and only between 45-60 mph.. I thought a bearing was going but I tried doing the wheel shaking to see if there was any play in the wheels but there isnt any.. Basically I've replace everything on the drive train I dont want to do the hubs at 286 a pop to find out its not the problem! There would be a mushroom cloud present on the eastern sea board if the sound continued after that
Old 10-30-2011, 01:34 PM
etbracket's Avatar
Sometimes you will not get any movement from a bad hub. You have to also spin the wheel and listen for a noise or get the car up on a lift put it drive and have some one listen for a noise.
allciuyt
10-12-2016 09:52 AM
Lobby Manager
03-30-2009 09:33 PM
jenne
09-27-2008 04:53 PM
hermxl1
05-14-2008 10:50 AM
gigantor
05-09-2008 05:23 PM
Quick Reply: 2005Cadillac Srx rumbling/grinding noise rear end!
