Sponsored by:
Sponsored by:
Idle problem on '95 Seville Northstar
Old 11-01-2009, 04:58 PM
french-jeremy's Avatar
Default Idle problem on '95 Seville Northstar
Hello,
I'am french; i have a '95 Seville STS with Northstar. It had 100 000miles.
The motor start and run fine.
But when the motor is hot, if i cut off motor, and i restart 5 minutes later, the idle is at 1900rts/min , and if i accelerate, it down at 600rts/min ...
Is it EGR Valve problem, or IAC valve problem, or problem ?
Excuse me, for my approximative english.
Thanks.
Old 11-01-2009, 06:12 PM
Check for codes, see FAQ section. It would be worth while to get Factory Service Manual - French version (Canadian). Has anything been done prior to this happening?
Old 11-02-2009, 07:59 AM
Hello,
I have touch nothing, just drain oil motor and change oil filter.
Old 11-02-2009, 10:42 AM
99STSGUY's Avatar
You need to provide a lot more infofor us to help you out.
Old 11-05-2009, 05:11 PM
Rzr's Avatar
Rzr
Rzr is offline
Default probably an IAC
Probably has something to do with ur IAC valve heating up... take a look at that.
on a side note i had a similar problem on my 91 Seville but after using "seafoam" in the engine my idle problems were almost eliminated. i highly recommend it if it hasn't been done already, especially with such high milage. that would be my first recomendation for trying something because it costs usualy abut $10 (american dollars) and even if it dosent solve your problem, at least you cleaned your engine a bit and that goes a long way in car care.
DanVB1
04-20-2023 01:11 AM
bobbyking1988
03-23-2013 04:19 PM
Albert
Eldorado Seville
03-14-2010 09:18 AM
fabes
10-29-2009 12:05 AM
97Caddy
09-12-2008 04:31 PM
Quick Reply: Idle problem on '95 Seville Northstar
