Sponsored by:
Sponsored by:
1997 sedan deville diy replace ignition wires
Old 10-15-2006, 10:51 PM
bwickes's Avatar
Default 1997 sedan deville diy replace ignition wires
1997 deville 100,000, need diy help on replacing plug wires. any info appreciated
Old 10-15-2006, 11:59 PM
FLCaddytech's Avatar
Default RE: 1997 sedan deville diy replace ignition wires
very easy, no special tools needed.
Coils should have numbers that match the cylinder they fire.
Front bank is 2 4 6 8 left to right
rear bank is 1 3 5 7 left to right
Old 10-16-2006, 12:01 AM
brougham1's Avatar
Hey bwickes: What kind of help do you require with the plug wires???? It is a pretty basic operation, you do one plug wire at a time , that way you won't screw up your timing sequence. If you are doing the distributor cap at the same time you would leave the plug wires attached but remove the cap and pull it to one side. Then proceed to replace the plug wires one by one and pay attention as to the location of each wire on the old cap as you put a new wire into the new cap. After they are all done then you can put the wires into the clips that hold the wires off the maniflod etc. Good luck, Don.
Old 10-16-2006, 12:07 AM
bwickes's Avatar
thanks for the help
Cadsforfun
06-28-2013 11:41 PM
Sonata
03-09-2011 01:10 AM
Reloaded
Cadillac EXT
09-14-2009 05:21 PM
tncadillac96
12-11-2007 01:05 PM
Quick Reply: 1997 sedan deville diy replace ignition wires
