Sponsored by:
Sponsored by:
03 Deville. Valves rattling
Old 05-10-2010, 06:54 AM
88Diesels's Avatar
Default 03 Deville. Valves rattling
I have 160000 on a DHS. I've notice lately. With the gas pedal partially pressed down and around 30-35mph. The valves rattle until I press further down and the car picks up speed. Not sure if it's not getting enough fuel or the tranny not down shifting at that speed?
Old 05-10-2010, 12:01 PM
Codes? Carbon build up is a possible cause.
Old 05-11-2010, 03:44 AM
88Diesels's Avatar
The only code is 0420. I've replaced the CAT and all the sensors. I didn't have this problem until I had to replace the Phelum. I sprayed the intake and then the code started.
Old 05-11-2010, 04:55 PM
I would review plenum repair. EGR would cause it but should set code. Carbon build up seems to be mostly likely cause - either on pistons or within EGR system.
Old 05-12-2010, 04:08 AM
88Diesels's Avatar
I will check the repair. How would I rid the carbon at the piston?
MYCADYGT
09-15-2008 11:54 PM
TurboLac
Aluminum Block V8s
02-09-2008 12:55 PM
caddymaster93
09-19-2007 10:55 PM
84CONV
Aluminum Block V8s
05-16-2007 04:19 PM
fleetwoodmack
09-02-2006 07:56 PM
Quick Reply: 03 Deville. Valves rattling
