98 sls running hotter than normal
Old 10-31-2009, 09:51 AM
majbarron's Avatar
Default 98 sls running hotter than normal
My 98 sls is running hotter than normal. It takes about 25 minutes of driving then the temp goes to 1 oclock from 12 o clock and fluctiuates from there (a little more a little less and so forth). Mechanic couldn't find problem. Different mechanic and chilton manual suggested an air pocket but didnt tell how to drain. any ideas on how or any other ideas on this problem.
Old 10-31-2009, 10:04 AM
dup post...............
Old 11-04-2009, 08:11 PM
Mrmojorisin's Avatar
New thermostat and or change your coolant.
When was the last time your coolant was changed ?
It is very very important to perform regular maintenance.
Can save one thousands of dollars in the long run.
tonyp56
09-12-2021 10:07 PM
majbarron
Aluminum Block V8s
11
11-09-2009 04:51 PM
tn350
04-09-2007 11:42 AM
Brupar
11-02-2006 11:36 PM
Quick Reply: 98 sls running hotter than normal
