NEED HELP WITH F CODES
RE: NEED HELP WITH F CODES
I found a table for you:
1980's Diagnostic CodesThe following codes are programmed
into the BCM
Code
Circuit Affected
F00
No BCM System Faults
F10
Outside Air Temperature Circuit Problem
F11
A/C High Side Temperature Circuit Problem
F12
A/C Low Side Temperature Circuit Problem
F13
In-Car Temperature Circuit Problem
F19
Blower motor failure
F32
BCM to ECM date transfer problem
F40
Air Mix Door Problem
F41
Cooling Fans Problem
F46
Low A/C Refrigerant Condition Warning (1/2 charge)
F47
Very Low A/C Refrigerant Condition Warning (1/4 charge)
F48
Very Low A/C Refrigerant Pressure Condition
F49
A/C High Side Temperature Too High (temperature exceeds 200°F)
F50
Coolant Temperature Too High (exceeds 259°F)
into the BCM
Code
Circuit Affected
F00
F10
F11
F12
F13
F19
F32
F40
F41
F46
F47
F48
F49
F50
