I need help!
Old 09-06-2013, 02:39 PM
HGW59's Avatar
Default I need help!
Dear all,
I have a problem with the ignition of a 1966 Cadillac Deville. Somebody mixed up the wires and I do not know, which plug is the #1 cylinder on the distributor cap. any ideas?
And firing order is 1-8-7-2-6-5-4-3 . Correct? Its a 429 engine.
Unfortuately there are no numbers on the cap.
can you help me?
Hans
Old 09-09-2013, 12:41 AM
HGW59's Avatar
Thanks for all your answers.
Meanwhile I found out otherwise.
HGW
Old 09-15-2013, 12:02 PM
dons2277's Avatar
Number one cylinder is the front right (passenger side) cylinder, and the cylinders are numbered 1-3-5-7 on the passenger side, and 2-4-6-8 on the drivers side. if you get the number one piston to the top the rotor will point where 1 is use a #2 pencil to feel the top of the piston after you pull plug
Old 09-17-2013, 02:48 PM
HGW59's Avatar
Hi Dons2277,
Are you shure? My 66 Cadillac 429 engine is wired
1-8-7-2-6-5-4-3
and is running with this firing order.
Would it run, if it is wrong?
Hans-Georg
Old 09-19-2013, 11:47 AM
EricD's Avatar
I note that HWG59 found answer - for info wiring diagram at What order do the wires go on the distributor cap - Fixya
Gregg Reed
04-13-2014 09:09 PM
cadillactt
03-12-2008 01:31 AM
kmac171
02-20-2008 10:36 PM
nizmosis
09-30-2005 06:20 PM
redbirdT/Aws6
12-22-2004 01:31 PM
Quick Reply: I need help!
